CEP dry sump
CEP dry sump
So I started installing the dry sump today.
The fit is perfect, as I expected.
Took me about 15 minutes to attach the pan as pictured here.
You can see how the stock gasket is used, making things easy.
Also of note is that the stock oil pump is disabled, of course, as you would expect in a real dry sump system.
There are a couple of neat tricks visible in this photo, the practiced eye might spot them......
Of course I will dyno this mod next week sometime, I am sure it will be running in time to take my daughter toart class on Friday.
Many more pictures to come soon.
I just couldn't stand the oil leaks any more, guys.
I am sure Dave will be happy to answer any questions.
woooooo ge I'm realy starting to feel less of a man .
RESPECT that **** is hardcore .were did that come from ?
how far will you lower the engine ?
I was promised a part number for some replacement mounts that take it down 10mm and retain standard sump .
Is that a new cast pan, or was it welded up? Doesn't look like the later.
Thanks Duke.
where are you going to put the oil reservoir?? now that you are going dry sump can you just flat out remove the AOS (could you before you went dry sump?)
that looks great! i cant wait to see it in action.
UAE Rennlist Ambassador
Dude, you seriously need to stop playing with that engine, i believe you never ran an engine for over 4 weeks without touching something........
Looks like you are squeezing ever last mm in that engine for improvement (you are still running 2.5L right?)
