"Clack clack clack" coming from left rear wheel
This problem is only intermittent, and when it does happen, will only make the sharp "knocking" or tapping when accelerating. At cruising or decel (regardless of speed), no sound can be heard.
Bad halfshaft? I can't imagine it's the bearing; I've never heard a bearing "tap" before. Could the halfshaft be misaligned?
What should I check, and then after checking, what should I replace?
Thanks!
Thanks!
I never notice, anyway
A good grease repack should clear it up. It's a pretty quick and easy job.
You'll need an 8mm cheesehead socket. If you can't find one around, let me know - I've got one at home.
dime, thanks for the offer. I know I don't own one, but I think I should be able to get one. The boots are in fine condition and are not leaking at all... I'll get in there and repack it then as well.
Our CV joints are notorious for losing grease with no trace of where it went.
Collin, Sears occasionally carries them. I had to call my Snap-On dealer friend to get mine.
Sounds exactly like what happened to my car back in 2005 -- for me it was my half shafts needed to be replaced. Actually I think you can just flip them to avoid buying new ones.
