Bigger Injectors Advice
#63
it turns out the 1000cc RC injectors are actually re-branded lucas injectors.
according to the injector guy, there are only a handful of companies that actually manufacture injectors, and the rest just re-brands them.
also, he was curious what the 951 uses to drive the injectors (peak and hold?), as that will affect the results. anyone know?
#65
testing completed. here's the spray pattern comparison. it looks like the stock bosch has the finest spray, followed by the lucas/rc 1000. it's a tossup between the siemens and delphi. this was surprising as i thought for sure the finer holes in the delphi would have resulted in a finer spray, but it doesn't work out that way. the simple pintle style of the plain old bosch actually produces a finer spray.
another interesting thing to note, the spray pattern does not noticeably change between 20psi to 100psi of fuel pressure.
more info to follow later.
