Bigger Injectors Advice
Small Business Partner
www.injector.com
these are, in fact, the very same injectors for $59 that lindsey, vitesse, and others sell for $80+.
if you get the low-impedence siemens 55lb, you don't need resistors as they are stock fit plug and play.
+1 on marren fuel injectors;
www.injector.com
www.injector.com
The Siemens 55lb injectors, part #3102, are only 2.35-2.4ohm resistance whereas the stock ones are 5.5ohm. Not much difference but, it's worth noting that they aren't the exact same resistance so I'd still run resistors just to be safe.
http://www.rceng.com/Peak-Hold-Injec...top-P11C5.aspx
What you need for 800whp just if you needed to know. Personally I wanted to do twin 500cc setup per runner but no room with nitrous.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I see the injectors from racetronix says there are flow each and everyone but when you order them do they come with the flow charts to prove it like they do from LR???
2.8 ohm. 3105's all four dead even at 2.8
Bosch and Siemens are under the same company umbrella so quite likely they're made by the same guy in the same factory type of thing.
I run 72lb Siemens which I purchased from Racetronix
. I also run 2 resistors on a small aluminum plate to act as a heat sink. One thing to note when making your plate is to ensure its small enough that you can pull it through the "snorkel hole" through the firewall with the main engine harness otherwise you'll be un-sodering the connections if you need to pull the engine for any reason.
![](http://img410.imageshack.us/img410/4837/injectorresistors002un2.th.jpg)
A shortcut for removing the engine is unplugging the harness from the DME/KLR and feeding it through the hole, so you dont have to unplug anything on the engine sit while its in the car.
disconnecting wiring on the motor side was much faster and easier.
after trying it both ways, i don't think it's a 'shortcut'. i found it easier to leave the harness than try to disconnect all the related wires in the footwell, snake it through the firewall, snake it back, reconnect, clean up, etc.
