Manual steering question....
Anyone know if the manual rack from an early 924 will work on a later car. I know the tie rods would need changed out, but what about the rack itself?
I'd assume the 924 rack is the same as the one on the 944, so it should bolt right up.
I'm 90% sure they are the same rack. I know an 83 944 Manual rack is a direct swap onto any other 944. All you need is the rack and the shaft (the manual one is longer), and tie rods and you are good to go.
Yes, that's why I'm trying to figure out if they will work or not. I guess the big question would be what intermediate shaft I would use given the splined shaft is shorter. Ready to part the '83?
hmm... so the 924 rack is a 477 #? Is it by any chance a VW or Audi part?
Also... is it just me or would the 924's solid mounts be preferred to the 944's rubber mounts?
