Tial...drill out dump port flange threads???
I'm pretty sure that I need to drill out the threads on the dump port flange so it can be torqued to the adapter plate. Just figured I'd verify before I put it in the drill press... Thx!
Application is a tial 38mm (older myswiss kit...but I don't really think kit wise it matters, flange is threaded regardless)
Yep, just start cutting right below the doors and you'll have a two piece 951 in no time.
Wait a minute why the hell would you use a sawzal? He's trying to mount his Tial!!
And yes drill them out.
I used it to cut through the studs on the flange on the stock WG. I forget why, but there was a reason. Worked well, didn't cut anything that I didn't want to, maybe I was lucky
Also the inlet pipe was no longer welded to that flange, so I had to have it re-welded at a shop
