Homemade Steam Vent kit: Advice . . .
resident n00b
I want to put in a steam vent kit, but i cannot afford $65 w/ shipping for 2 connections & a hose. (Sorry LR)
I've read that few of you have built your own.
Any advice on which hose to use? & where to get it?
Are brass fitting OK to use, or is steel a better choice?
thanks, Jake.
thanks, Jake.
I have used PEX tubing in plumbing applications before. It is flexible and high heat resistant, but not very UV resistant. I am not sure if that is what LR uses, but when I opened my kit that is what it looked like. I don't know if this helps or not.
resident n00b
On the same note. I just bought a LR kit with the 'T' fitting in a sealed bag from a local guy that sold his car. Are there supposed to be instructions with this kit? I know where to tap the head but instructions would sure help. The fitting looks like an NPT. To me this means I should tap the hole in small steps, test fit, tap some more, until the fitting is snug. If you keep tapping all the way without test fitting the hole will be too large and leak. If someone has the instructions I would appreciate it.
Find yourself a Parker Store.
Get two 90 degree "Presto-lok" fittings that swivel - 1/4" NPT will work.
Get a 1/4" NPT "T" fitting and two barbed hose fittings.
Get about 5-6 feet of high temp 1/4" nylon tubing - Parker Paraflex hose.
Drill and tap a hole at the back, upper corner of the head. There's enough info floating around here to let you know where to drill. Route the nylon hose as you see fit. Finally, splice into the small coolant tank hose and install your "T" fitting AND YOU'RE DONE!
Nice little upgrade if you've got the head off - cheap and easy.
Jake, I've got a bunch of the nylon hose, so if you're not able to get a 5-6' section I can hook you up.
its descusting that this is worthwhile mega bucks in R&D a car that cost more than a house from the dealer .and about 50 meters of coolant hose already .
tell me about some coolant pipes i can get rid of
