Power Perfect Fuel controller
Can someone help me with this? I've down loaded the tuning program from LR's site and am trying to set up a test map file. When I get to the "Edit/Match" to choose the "Meter to use" "Meter to Match" all there are some default options and I can't change them to what my set-up is. If anybody has experience with with program would really appreciate some insight.
Thanks for the help
Thanks for the help
What set up are you using? I have the map that Wes used for the 340 kit. I can send it to you if you need it. I have the PowerPerfect and will be tuning all this week starting Tuesday. Give ma a couple days with it and I'll try to answer your question.
Using the same 340 set-up except for I went with the Super 61 turbo. Did you down load the program from LR's site and have you been able to create a map for yourself? Very interested in how it all works (Power Perfect FC) for you, keep me posted. Thanks for your input. BTW your set-up is very similiar to what I'm currently putting together.
