Lindsey Sport Turbo leaking oil
I recently bought a Lindsey Sport Turbo after my previous K26/8 turbo disintegrated on me. The shop installed it and fired up the car and it ended up burning significant oil. So much so, that when the car was test driven on the street the driver compartment was so smoky that you couldn't see.
I have bought numerous quality parts from Lindsey so I think that they are a reputable vendor and Dave claimed that there might be mechanical problem with the turbo. Before I send it back I was wondering if anyone had a similar problem with Garret based turbos?
I read on the internet that a common problem with Garret turbos is that they cant handle the oil pressure of a 944 and that restrictor plugs for the oil cooling and catch cans were common practice.
I didn't want to lose the rest of the season so I installed another stock K26/8 and the car performed perfectly. Therefore, the problem was definitely the turbo.
Thoughts?
Thanks,
Andrew
Thoughts?
Thanks,
Andrew
No. I'll let others with Garrett experience answer your questions.
Care to elaborate on the rest of your 951? Nudge, nudge, pics, pics.
Im can not comment on LR turbos I Know from past experience that LR are good suppliers and stand behind their products, but I can give you my 2 cents worth on Garret turbo's.
When I installed my Huntley racing stage II BB turbo it ran well for about 1 season
the following season it it started to smoke a little and by the end of the season if I let the car Idle for any period of time it would smoke profusely until the excess oil burnt off.
I can also tell you that Huntley got his turbo's from Magestic turbo in Texas. Many listers have had problems with these units. do a search in the archives, you will surly find some info and see if there is a solution and or fix to your problem.
Cheers.
Just have a look at the Avitar. it smoked.
great moskito repellent, keeps others far back on the track
Cheers.
Sure, Here is a pic of my 951. It has a full LEDA coil over system with 500lb springs and adjustable valving from Racers Edge, all solid bushings and camber plates and control arms from Racers Edge. It also has a Lindsey dual Port Waste gate and manual boost controller and runs about 16 lbs of boost. I had the head redone and have a stronger seal so it should theoretically handle more boost as it is grooved as well. Sparco Evo L seats and 5 points, AIM Hotlap system, etc. It has no cat but a stock exhaust.
It was making excellent power before I blew my turbo but thats because my shop modified the turbo without letting me know and I beleive the Air Fuel Ratio was too lean as it was pushing more air and no one knew.....I have bought a boost gauge as well as a wideband A/F ratio gauge so I wont have the same problem.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![Name: CMT 2006 BMW FEST EAST 027-3.jpg
Size: 96.7 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/214084d1187970951-lindsey-sport-turbo-leaking-oil-cmt-2006-bmw-fest-east-027-3.jpg)
Full(canister double adj.) Leda coil over, 900 & 1000# springs
Vitesse Stg 3 turbo, maf, 4" cup exhaust
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Full Racers edge bushings, Charlie Arms,
Full cage, Gutted interior, lexan rear hatch
tires, 13x25x16 R 10.5x23.5x16F slicks+ fender flares (not installed at the time of the picture)
sparco seats, removable steering wheel
Stock size 87 brakes, Hawk blue pads. the less you brake the faster you go.......
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
weighed in at 2840 with me in it, 4 # differential front,10#rear
Race pac Data Aquisition.
Its Stock I swear!!!!!
Nice, what year is it? How do you like the splitter and the front air intake slot in your upper fascia? I was thinking of getting a splitter as well as that opened up fascia to cool the engine? Does rain get in your air filter?
it's an 87,
Splitter helps cut lift at high speeds, facia opening is for the intercooler, it makes a difference.
my air filter is where the drivers headlight usually is, if it does get a few drops of water when it rains, no biggie.
cheers
cheers
If it's the fault of the turbo, I'm sure LR will take it back, send it to the guy who rebuilds their turbos and send it back to you. We bought a used/rebuilt one from them 4 years ago for the track car that was rebuilt by the same guy...retired, hhmm,,cough, cough, used to work for some guy named Penske.
Any new Garrett turbo works perfectly fine. There are a lot of misconceptions and people seem to think that certain turbos are horrible and will leak oil all the time which isn't true. You have to be careful because with some models of turbos (especially ball bearing stuff), you need to use restrictors as they can be very particular about how much oil pressure they receive. Also, turbo rebuilds can be like russian roulette. I've personally known a few people that have had rebuilds done at Majestic, and their stuff has worked perfectly fine. I've also known and talked to a number of people that had lots of problems with "over oiling" causing leaks and smoke.
