That might solve the disappearing coolant trick
Alright so I pressure tested it today and had terrible luck. At 10psi there were no visible leaks but when I increased it to 15psi there was a slow steam out of the area in question. There were also a few drops coming out of the small line that attaches to the waterpump.
GRRRR!!!!!
GRRRR!!!!!
The second leak is object number 7 in this link...
http://www.pelicanparts.com/cgi-bin/...03&Line_Item=5
It doesn't should a gasket should be there, just a seal ring. Is that right?
Should I replace object 7 too since its less than $10?
Those housing are a common leak. They tend to warp and create a gap that cannot be closed with just two bolts. Get the housing and the o-ring. The o-ring is the only seal in there.
If you take the housing off and put it on a flat surface, you can usually confirm that it is warped by sliding a feeler gauge under it.
