FS - Fikse FM10 wheels, 17 x 8 & 10
Looking to raise some cash for Stage II cylinder head.
Fikse FM10 wheels for sale. Wheels are straight with no curb marks.
17x8 w/ 43 mm offset (225/45R17 Kumho MX tires included, 60 % thread)
17x10 w/ 55 mm offset (rear tires are junk)
Asking $1400
Was told by the previous owner that these wheels are orignially made for 944 turbo cup car. I couldn't get it to fit in my '89 951 with stock camber setting. You will likely need 2 or more degrees of negative camber to fit inside fender. Buyer is responsible for fitment.
Asking $1400
Asking $1400
Asking $1400
They fit perfectly, in my opinion (I have the same wheels on my 951). I had to run some 7 mm spacers up front to clear the wheel bearing hub cover, but they fill up the wheel wells perfectly and they don't rub on a stock height car.
Regards,
Regards,
More picts per request.
Rear fits just fine w/ 1.2 degree negative camber.
Front as you can see sticks out w/ 0.8 degree negative camber. 2.5 degrees should tuck it in just right.
