Possibly looking for a MAF
Budding Photographer
Rather than criticize someone for an honest yet personal review of your product's pricing why not respond in a positive way such as "we may be more costly than most other's but you'll find our products are worth the extra money after you purchase them!"
Dan is an astute consumer of Porsche products and I have known him for some time both on and off the list. We have talked in detail about your product and his desire to purchase your system yet he has not d/t pricing alone. Now if Dan was bashing your product on performance issue alone while having never purchased it, then I could understand your position.
Again, I don't see your point in e-mailing him simply based on his comments.
Regards,
Cory
The APE MAF is a 30C MAF.
Unless you have lots of experience with tuning or are willing to spend lots of time learning (possibly the hard way at your car's expense) I wouldn't suggest a used one. If it's used, someone probably got rid of it for a reason.
I only have experience with the Vitesse MAF. Maybe not the cheapest, but you have to consider what your time is worth. Especially on a Sunday when you really want your car to run and you get a call from John to help.
I am starting to get fed up of this brown nosed "Its johnD's forum" business
Rennlist is a private members forum as John D keeps telling us, non members are free to post too JohnD simply administers it and takes a pretty good profit for the privilige (thats business). John D seems like a really good bloke from the emails we have exchanged. But he has said on many occassion that this is our forum with a few Caveats.
If you check the rennlist rules it states that you should not make public personal communications. I got flamed for it once and as I recall "Shaheed" was most correct to do so, although I did not see it that way at the time I was wrong to do it.
John from Vitesse supports his products outside of business hours and offers fanatical support that others chose not to. That is his choice I know but don't flame the guy for his sticker price when you don't know what you get for it.
OK i will come down off my soap box now!
Cheers
Tom
Cory,
Cheers
Tom
Cheers
Tom
OK, I hope that's settled and we can get back to the topic?
Just so we're clear that you aren't being singled out here, Dan - posting private email and/or PM correspondence on the forums without prior consent is specifically prohibited by the Rennlist Charter.
See item 5:
https://rennlist.com/charter.htm
Thanks.
See item 5:
Thanks.
I just stopped by John's house last week and picked up his MAF kit and some bigger injectors. My car ran great with the autothority setup (actually surprisingly well), but I wanted bigger injectors and plan on more mods in the future. For some time, I considered going a cheaper route- I had to remind myself of what I have already been through with these cars. John's kit is the ONLY way to go if you want the ride to be 'headache free.'
Disagree with me if you like, but I have been there and done that- quite a few times over now.
See item 5:
Thanks.
See item 5:
Thanks.
Cory,
Cheers
Tom
Cheers
Tom
Correct me if i am wrong.
As I understand it the Vitesse MAF and SciVision MAF work two different ways.
The Vitesse MAF has a new chip set up and the Sci Vision uses the existing chip set up.
Therefore that may be one reason that Vitesse MAF is more expensive since it works differentely and has a new set of chips.
ALSO, IF ANYONE HAS ANY INPUT............is a MAF night and day from an AFM? Or is it just a marginal improvement?
26/6
3 bar FPR
LBE
stock injectors, stock WG (that somehow holds boost well)
I don't want to spend a bunch of money on a MAF just to find out that the same money into a new turbo or 27/6 upgrade would have made a better choice.
The problem with the 27/6 is that the chips alone cost $795, so adding that to a $700 upgrade is more than either MAF.
26/6
3 bar FPR
LBE
26/6
3 bar FPR
LBE
26/6
3 bar FPR
LBE
As for a difference with a MAF, you kind of have yourself in a catch 22. On a mostly stock 'chipped' vehicle you won't really gain huge HP. You will have enhanced drivability and overally criper response. So logic would say go spend your money on a bigger turbo. The main reason people use a MAF is when they have a turbo/exhaust system which will outflow the AFM. So you spend your money on exhaust and a big turbo, now you need a MAF. These cars just eat you...
It all depends on your HP goal. If you went to a moderately larger turbo, 55# injectors, chips, 3.0bar FPR, 3" exhaust you're fine with the AFM up to about 300HP. If you want to do more, then you can add the Scivision later.
When we do a set of chips, and you change configuration and need a new set, you are charged a re-tune fee, not the full price of the chip. Our chips retail at 299, when purchased with the Scivision you get a set optimized for the Scivision (as part of your new configuration) they are only 200.00. A re-tune at any time is only 150.00.
We make the upgrade path a little less painless, without sacrificing quality or support.
Regards,
Russell
