No start after turbo install
#31
Don't think it's been mentioned anywhere in this thread... Check the engine ground(s). The one buried at the back of the motor is critical. Be sure it's tight and corrosion-free.
#32
michelle try jumpering your factory alarm if it isnt already that was my problem. Tach bounced but no go and jumpered the alarm and vroom right up or if you had the DME unplugged make sure its seated all the way
#33
Jane Bond 007
I'm starting to lean toward the alarm after all I've read and heard. Car sat for two years with a dead battery and I've heard a few war stories about alarms after a scenario like that. I'm going to check it out tonight. Thanx!
#34
Hmm where is this ground located? My car will not start a few tries. It always felt like a bad ground. though, once i spray the intake with starter fluid, starts right up, still would like to check this ground out.
#36
Jane Bond 007
Well, the no spark problem WAS the alarm. I now have spark to the plug (yay!), fuel to the rail (yay!), but still won't crank (damn!). I need to see if the injectors are firing but AutoZone no longer carries NOIDE lights. ANyone know how to check this without a NOIDE or where I might be able to find one?
