Magnacore Wires -
No vice grips were used in the filming of these wires ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
It happened so fast and with so little effort from me that I was a little shocked when it happened. I have replaced hundreds of ignition wires in my 21 years of racing and have only seen something like this happen a few times - coming off yes, but going on?
John, pics below. It looks like it was pulled off at an angle by the wire, but, of couse, was not. I was installing it and pushing straight down with my hand.
Jakery, the number to Magnacore is 248-471-9595 or you cam email them at; mag@magnecor.com.
RM512, you are absolutely right! The instructions state, much to my surprise, "Important: DO NOT stuff silicone grease into boots, as the terminal inside will not lock onto the spark plug top properly, if at all."
My set tore exactly like the pictures above. Also, I believe it was the same wire that tore, but after a month or so of having the wires my car began sto misfire badly under any boost, but ran fine normally. Tried alot of things to figure out the problem. Ended up putting my stock wires back on and she ran like a top. So far, not impressed by magnacore...
Seeing those pics, that would lead me to believe that you guys are removing them by pulling on the thinner section or base of the plug boot itself. I personally only grab the larger section that fits down into the spark plug hole by slipping something in the corner of the plug hole to get an end of it sticking out. You might try doing that as all the force of removing the plug wire, and focused in a small area like that might be why some of them are ripping.
resident n00b
I broke mine installing the damn thing for the first time. It wouldn't sit flush so i was pushing on the base.
I called Steve at Magnecore & he told me to mail the wire to him & he would fix it & get it right back to me.
Good customer service, but i don't know if i'm in love with these wires, I was having a minor mis-fire issue under initial acceleration, and now that i put my old Jacobs cables in, its gone.
Tore 3 of 4 Magnecore boots in different places this weekend while putting new NGK plugs in. It was ridiculous how little effort it took to rip them. I tore the first one pulling at the stem, tore the next two while using an angled flat edged "tool" to pry up the base of the boot to try and prevent the first tear from repeating. The inside of those two tore, leaving it stuck on the top of the plug. The 4th one I just got lucky and it didn't tear.
Very disappointed with the boot quality of these wires. Would not recommend them.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I used to swear by Magancores…and then I started swearing at them!
The boots are absolute junk, not made for the 944. If you are careful they will not rip – but they will lose the tightness of the connection to the spark plug after a number of connects/disconnects. I will say that Magnacore is quite good about replacing the ripped boots, I have had quite a few replaced over the years (for customers cars).
I did have one set that failed internally that drove me crazy. Occasionally miss that only happened when over 15 psi.
Now I make my own….
Now I make my own….
