Smaller alternator issue completed(pics)
#121
I have a 4" intake, and the Nissan alt wiring on top is a disadvantage, but it does clear my particular intake well. We only installed the Nissan alt because of clearance issues. We did lower the alternator, and must have installed and removed the alternator and bracket 20 times to get the desired results. If you are just installing the Nissan alt, and not modding the lower bracket, this is a fairly straight forward install. I attempted to state this in my post, but didn't do a very good job. I assumed that folks did this for clearance issues. I stand corrected.
Know, this alternator has material removed as does the bracket. I can't just put in another stock Nissan alt as a replacement without modding the mounting points again. Hopefully it will last for a while. I'll either purchase a bracket when this goes, or have this particular unit rebuilt. I don't "love" working on my cars. I love driving them.
Thanks, look forward to your PM.
As I mentioned, it seems simple enough just to fab a small, but stout bracket bolted to the lower mount with enough offset to clear a second bolt to secure the alt to. You would need to remove however an equal amount of material (thickness of the bracket...say .250) off the lower alt tab to maintain alignment. Again, in looking at this possibility using the upper mount as a point of reference, you would be swinging the alt upwards toward the turbo inlet pipe. This in effect offers diminishing returns of using a smaller alt. to begin with. I believe it would still clear a 3" pipe, but as someone has pointed out the location of the stud for power connection is right at the top of the alt. and could possibly rub the pipe connection. Maybe.
#122
I finished this install yesterday, took me 3 hours.. and a lot of that was spent double checking measurements and such.. belt is dead on straight (I had 2 Bosch alternators so I used the pulley off of one, and used the second as a comparative for spacing from the front of the pulley to the mounting lugs to ensure the pulley location ended up with reasonable tollerance of where it needed to be!
All in all I am happy with the results, and one thing I havent seen mentioned here is the new alternator is MUCH more efficient than the Bosch unit, hence it takes lower belt tension to prevent squeel, and will require less HP to turn... is moderately higher output, but the later Quest vans were available with a 250 A alternator... I will be using the higher output alternator on my 951 when it goes back together...
I guess I am one of the more refined home grind to fit opperators, but then I did stay at a holliday inn express once or twice!
If you have a machinist do this for you it could be finished VERY easily, and cleanly... but I'm happy with the results I got using a cut off wheel on my angle grinder and dremmel!
I would rank this between replacing a trans mount and doing a brake job in difficulty!
#126
Take the pulley from 1, mount it on the new alternator, use the second to map out the cuts to the new alternator... makes it quick and painless.. just have to cut a keyway into the shaft of the new alternator, a dremmel with a cutoff wheel makes short work of it!
#127
From: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
I too, have started this upgrade on my CA car. Just wanted to let everyone know that I sourced a great deal on the alternator.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
This is a brand new 125A output @1,200 RPM unit. He will also put on the six groove pulley for you. I ordered it on Monday, received in on Thursday. No tax and cheap shipping. Less than $130 total! I will try to post some pictures.
Note: I was able to retain the factory belt with my install using this alternator. I will post pictures soon.
#129
#132
Stock AC works fine. I used the same alternator as shown above by URG8RB8. Pretty easy install. Just need to mill a slot in the stock alternator cradle and mill down the mount lugs on the alternator itself.
Here are some pictures of mine done a few weeks back.
#135
Nice pictures above!!! Glad it worked out for you as well. I too have installed another one of these on my CA car this time. It worked perfectly. I had the same mod made to my factory mounting bracket. I read 14.2 volts while cruising at 70 on the factory gauge. Getting ready to install IceShark light harness, should be interesting to see how all this works out. I all ready have the IceShark battery harness with supplementals installed, Big thanks to Robby for getting me all those parts for two cars! It took a while, but Robby is a great guy.
