Downpipe
#62
Originally Posted by kasturbo
LOL...I wish that's all I had in her.... ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Originally Posted by RPHARRIS
...One thing I have always wondered is: which will make more power, a downpipe that is exactly the same ID as the turbine outlet, or a downpipe that is larger than the turbine outlet? Can anyone give me a straight answer to that?
#64
Originally Posted by Skip Wolfe
While this was for water, the same design principles should apply to air.
Cavitation does not exist in gas (without the presence of liquid droplets) so there is therefore no need to be concerned about erosion.
The gas out of the turbo swirls (like a helix), right-hand or left-hand depending on the speed of the turbine wheel. That swirling results in a longer gas path than a straight flow and is therefore more restrictive. It actually is an advantage to convert the swirl to a turbulent flow, which is done with the abrupt diameter change that happens from the turbine exit to the down-pipe (ref. MacInnes, “Turbochargers”, chapter 8 “Exhaust”).
Quantifying the effects of various dimensions requires either very good simulation tools or extensive systematic experimentation.
Laust
#65
"Number 3, Steve Timmons ruined the internet long before Chris did (sorry, Chris, you'll have to try harder! ) Any long time Rennlister will know who I am referring to. "
Now you've got me interested in these guys and their deeds or misdeeds perhaps...
Oh, and $6k, hell I spent about double that in the first major service I had
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
#66
I apologize for earlier guys. Hey RPHARRIS asked the question in a perfect way. Good thread, but I'm still not sure about the verdict. Does this mean that everyone owning a 3" downpipe wasted their money?
#67
UAE Rennlist Ambassador
remember, it is not only how much air you can cram into the engine, but also how well it get's out.
#69
One instance where I think a 3" downpipe is a must is with a T4 hotside. T4 hotsides have a 3" Vband dischage. A P-trim wheel is also big wheel and a 3" downpipe would make sense. To me it comes down to your hot side, If you are running a kkk replica and a stage-V or smaller wheel a 3" down pipe makes no sense based on price and install time, but it would still makea small difference.
#70
That's exactly what I would say.
#71
Thanks guys. From what you and hosrom are saying, it would make sense. I got the stage I turbo and headers from SFR and bursche exhaust. Haven't gotten a bigger wastegate though. I'll probably buy these from SFR as well very soon. Thanks guys.
#73
$4,800 bucks worth of upgrades....whew....yep you got us all beat....no one else on this list spending money like that....you're a wild man!
Hey but if I could afford it, I would too! Wouldnt you if you had a bunch of cash?
#74
Right now I have all the intake off and some of the bolts off of the turbo. All actually going well considering it has never been touched before. Anyways, I am having trouble getting to the one bolt on the downpipe that holds it to the car itself. Any suggestions?
