WTB - wastegate
I finally found the problem. Car was running badly under boost and would only reach 12 psi and fall to 8 psi quickly. I replaced all the vacuum lines which I needed to do anyways. I borrowed a vacuum tester and checked the wastegate and it is not holding any vacuum at all. Must be the spring is shot or diaphram.
If anyone has a lindsey or a tial 38 with adapters I am interested in buying it. If anyone has a good stock wastegate I may be interested in that too.
I have a Turbonetics Deltagate MKII wastegate in good working condition. It was pulled early this month, but I am not going to need. Shipped to your door for $95. Paypal accepted.
