CV joints. Better alternatives than stock /GKN?
#76
To eliminate vibration from the tranny we can just mount a rubber pad on the rod end.
"Doesn't bother me. In fact I'm impressed that sort of dog can type."
The dog is no longer with me. She was nearly as clever she could typing (or is my english so bad that its no different from dogenglish ;-) ) I could speak to her in the telephone and she answerd with a lot of strange low sounds. Her development the years she lived was to fast for the evolution so I suspect a higer force intefered and gave her canser as a crismas present :-(
#77
#78
Originally Posted by anders44
heh.. bloody hands, and a snapped bolt under the preload of tbar right side....
sweet race btw, gotto love that v8 sound though..
#79
Originally Posted by CMF
hello!
......ok... Very interesting... But what about the "Flange" at the wheel/hub?
there is custom made flanges. I take picture soon.
OH. Hey. It's you..... So you had Custom Flanges welded on to the Stock Spindle at the Swing arm? That makes sense. Just Scared of doing that since getting one welded on Perfectly straight seems like it would be almost impossible. But do-able.
I look forward to the pictures! Thank you.
#80
Looked soft. It wasn't It did take a bit for the boost to get going. But it definately could have gotten off better. That was a 2.0 60' time.
I think you took that the wrong way it looked like you left easy on it.
I just got my car ready today. I just picked up a set of Mickey Thompson et streets for 100 that were like new off craigslist, what a steal, these should cure my 2nd and 3rd gear spin problem
I will be heading up weds or maybe even tues for the race car tune if I get itchy.
Thanks again for the testing of the new bar. I hope it keeps my stuff together.
Don't know where I'll end up but it is running good right now.
Is there a correction factor since I'm at 5200 ft? J/K I want to hit the number don't care about the air just have to work harder.
Anyone else going up this week? To try for it?
#81
Naw. my posts sometimes come out harsher that I would like. Boost certainly took a while to come on. Seems to be the problem with these cars. I can Definately get it out there faster with a better burn out less air in tires and a better track. I would have kept going, but my Air Fuels scared the hell out of me, so I was happy to drive home. (trailer was un-available that weekend) So.
Do you guys know that higher elevations only really effect lag. Not power as much as you think on Turbo cars. Yes. the turbo has to spin a little harder. But it's still pushing in 15psi of air. 1 bar is one bar. No matter what elevation. So. If your boost gauge is reading 15psi. you have the exact same amount of air as I do at 80ft elevation pushing 1 bar. My turbo just works a little less giving up maybe a couple percent efficiency.
I'm not saying there's not a little disadvantage. But. No where near as much if you were NA.
ok.... I'm braced. I'm ready. Flame away.!
#82
No flaming from me I fully understand the air density in regards to boost (as in full boost)
The main difference is the time it takes to build apon the accumulated boost.
Example is it takes us up here about 3-4 psi to equal 1 atmosphere at your level. That in itself takes a little time (LAG) then you have the recovery on every shift.
I think I have a good setup going to eliminate it as much as possible, but don't want to get ahead of myself before some real numbers are generated.
#84
None the less. I would certainly say it's been a success. I doubt the CV would stay together if I took off the brace and launched the same way. I'm just not willling to test that. I have enough work ahead of me.
#85
#88
mine were not dry either. One of tem went after only 100miles on the car. I will stand by that I think it is the CV being compressed until the bearing are pushed through the cage.
With a solid transmission mount I have not broken any more, I have still upgraded my axles to be sure that nothing breaks from torque and not just side to side movement of the trans.
#90
Yes, the one I've broken was drivers side and was almost new, good grease, etc. Broke it when I was solid trans mount fyi on a HARD 1-2. Granted, I also sheared two stub axles and had a wheel bearing to replace so there was some abnormal play in my setup at that time.
