Do you really have to pull the crank pulleys to remove the rear belt cover?
Herr Unmöglich
After a month vacation in Europe, and all the beautiful cars I saw, I have returned home with a new motivation to get my turbo back on the road. I don't cut corners and so she is in the process of getting many of the basics in the engine bay replaced, all the way to the radiator, water pump, and a new stock turbo (my existing K26 has 197K on it). The top and bottom end were rebuilt by the PO but for some reason even though they did all the front seals they left the old crappy waterpump on there, complete with a thermostat that is missing the appropriate rubber spacer ring - it flops all around in the pump.
Last night I pulled all the belts and rollers, only to realize that the brand new rear belt cover that was installed on the car seems to require the crank pulleys to be removed to take it off. Now I know this was not the case on my 87 NA that I rebuilt last year.... what gives? If that is truly the case it make my life way harder, and for sure that stupid thing won't be put back on. I run the NA coverless with no problems, and would rather be able to look at the belts than have to deal with those stupid things.
Thanks for the Saturday morning help...
Herr Unmöglich
Wheeee. Makes for a fun day for me... Cascading issues of stupidity. When a PO did the cat delete, they welded the flange by the wastegate on incorrectly, so I can't remove the starter without taking off the exhaust. Which means I can't install a flywheel lock, which means I can't remove the crank pulley, which means I can't remove the belt cover or waterpump without removing the exhaust.
I do have a new wastegate so I might as well do it. But what a PITA. Thanks for the reply.
UAE Rennlist Ambassador
I was able to remove the timing belt and install a new one without removing the crank pulley.
It requires some minor bending and and rotating the crank a few degrees back and forth, but it is do-able.
Herr Unmöglich
I have the belt off no problem. But to do the water pump I need to take off the rear belt cover. And it actually looks like they used a liquid sealant on the water pump and not a gasket. There was all sorts of funky sealant goo all over this car. Whatever mechanic had his hands on this thing I would like to meet him in a dark alley sometime.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Jane Bond 007
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
BTW - make sure you tighten that @*&% crank bolt back down to spec or you won't have any oil pressure!
Rocket Scientist
Originally Posted by schwank
I have the belt off no problem. But to do the water pump I need to take off the rear belt cover. And it actually looks like they used a liquid sealant on the water pump and not a gasket. There was all sorts of funky sealant goo all over this car. Whatever mechanic had his hands on this thing I would like to meet him in a dark alley sometime. ![nono](https://rennlist.com/forums/graemlins/nono.gif)
I think I remember getting my water pump out without removing the rear cover. It required a lot of wiggling and messing around with, plus I think my covers were already cracked in half at the top. That made it easier. Just go try it, otherwise all you have to do is remove the crank pulley. It would have taken less time to do that then type this entire thread up and talk about dark alleys and such...
Yep, the PO got everything for the front end (rollers, seals, belts and pump) and then forgot to add that water pump gasket (it's like less than $5 or so), so the mechanic applied some high temp silicon.....looks like i will have fun getting that stuff off next time.
Lazer Beam Shooter
you can get the pulley off without a flywheel lock. you have to pull the radiator and use an impact gun though. Or you can put a ratchet with a long pipe attached and brace it on the ground and tap the key and that usually will take it off.
Herr Unmöglich
Thanks all. And I like the dark alley jokes too...
Anyway, the car is a big slippery slope for me. Lots of things I gotta fix, one being the exhaust anyway. So today that whole deal will come off anyway so I can do the wastegate etc. I will be swapping to a new turbo so I have lots of work ahead of me there.
Why is it never easy? Ah well.
I would get a flyhweel lock.
Worth it for any work you may do. Yes the crank pulley needs to come off to get to the water pump. This is one reason I don't run either belt cover on the 944 spec car. easier access to parts. I do run the covers on my Turbo S for street use.
Herr Unmöglich
I have one Joe... used it when I did the track car last winter. Except the NA is late and so you can pull the rear cover without taking off the crank pulley. I really don't like that design ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Managed to get the exhaust and starter off yesterday and the flywheel lock is in place. Now I gotta figure out how to bust that pulley loose.
