Exhaust leaks affect idle?
Drive-by provocation guy
Anyone had or dealt with real bad exhaust leaks and if so would they affect idle/vac??
I have a leak and think it is the DV, but if not then it has to be on the exhaust side, pre wastegate.
Anyone?
Anyone?
That's what I thought.
I will just try to change out my dc with someone local that has one to confirm.
I will just try to change out my dv with someone local that has one to confirm.
Really? Then why was my idle at a constant 950 rpm when I was leaking exhaust through my exhaust manifold gaskets? And why was my spool up so slow? Vaccuum leaks cause high idle...
Leak between the head and the turbo (in the header, crossover or at the WG inlet) will affect spool up in a bad way.
An exhaust leak AFTER the turbo can also affect spool up and performance, but in a good way
Originally Posted by ehall
... when you have enough knowledge to answer your above questions for yourself, THEN begin answering them for others.
Originally Posted by LFA951
Hey, I thought your last post was up a week ago....
They kept mespecifically so that people like you wouldn't pass on BS info, using half assed techniques and snake oil.
