Stock wastegate vs. Tial
#46
Originally Posted by toddk911
Yea, 90% of "rolling off boost" is just stock turbos running out of steam.
The wastegate bleeding exhaust is still a huge limiter. I had a stock turbo and noticed a huge improvement with the Tial and MBC. 90% may be too much of a number if you still have the stock wastegate.
I used have a LBE before the Tial and even with it set to ~14psi, it was bleeding badly. Once the tial was installed, I had to really retard the boost as it was jumping to 19psi.
#47
Basic Sponsor
That's exactely what happened to me.
#49
ok now i have been thinking and talking with a few people about this the tial gate gives you the ability to close it completly after it has started to open witch is good but i think that could put a lot of strain on the turbo like maybe causing it to over spin(?) exceed it maximun rpms. is that possable? what would be the outcome of that? i am not trying to say dont get a tial gate but on a 20+ year old turbo i think that would be bad any extra strain. maybe i am way off bace but i was just thinking about it
#50
#51
Drive-by provocation guy
No. By the wg bleeding off boost it makes the turbo work much harder and spin more to generate the desired boost.
#52
You are over-thinking this whole thing entirely too much. It's not that big of a deal. The stock wastegate is made from inferior materials, Tial wg's are made from superior materials (which are pretty much 100% resistant to corrosion). Stock wg is old single port technology, Tial is dual port newer technology. In general, trying to compare the stock wg to a Tial is comparing inferior/archaic technology, to new/advanced technology; newer is better in this case. As for turbo damage, that's not even an issue. The only way you are going to over-spin your turbo is if you pull the lines off the wastegate and drive around free-boosting.
#53
Basic Sponsor
Originally Posted by lart951
Bingo, at leat someone got it right. In my first dyno sheet, I had setup my MBC at 18psi, the dyno was done with the shimmed stock wastegate (aka Ultimate guru pos). When the tial was installed and I went for the 1st test drive, my vdo boost gauge was showing 24-25 psi of boost and I had to do 3 more runs to adjust my MBC down to 18psi. My stock wastegate was bleeding 6-7psi I was running 24-25psi of boost in order to substain 18psi for a brief period. I hope that explanation helps.
#54
Just to chime in here, I recently swapped my stock wastegate with a Tial 38mm one and instantly noticed boost hit harder and faster. It was night and day (and I had a known good stock wastegate). This is on a pretty stock car. Stock turbo, just chips and 3" exhaust. It is currently running in single port mode, but as I said, it still made a vast difference in boost spoolup in every gear. I'd never go back.
