New dyno pull, how are my numbers?
The boost line fell off half way through, so thats why it all of a sudden goes to 0 boost The other run went up to 17 pounds and fell off a little bit but not to badly. I would assume its because of the stock wastegate.
Ok, Here are the engine mods:
951max chips
LBE
3 bar FPR
2 wastegate shims
Forge DV
3" exhaust
test pipe
~17 lbs
Mustang Dyno
RWHP: 235.4 @ 4640RPM
RWTQ: 307.7 @ 3570RPM
AFRS went from 13.4 steadily to 12.0
Hows that sound? About right? The hp number seemed a touch low. It was really hot today, may have had something to do with it
Jeff
951max chips
LBE
3 bar FPR
2 wastegate shims
Forge DV
3" exhaust
test pipe
~17 lbs
Mustang Dyno
Jeff
Is that far right column your boost pressure? Maybe you blew their boost gauge line off your car and started leaking boost at 3652RPM.
Edit--- Upon rereading of your first post I guess that's exactly what happened.
It is, but we did a run after that, with the boost line reconnected, and the numbers were slightly lower (although it did hit 17-18 pounds). He said since everything was heating up it would effect the numbers.
Originally Posted by jmporsche944
Alex - Im not sure, maybe russell will chime into this thread.
Good, are the numbers on par with what you have seen in the past Russell?
To be completly honest, I dont care about numbers that much unless there is a PROBLEM causing it to be not running right. The car pulls damn hard IMO, which is good enough for me
