Is the k26/8 swap worth it?
#31
TRB0 GUY
Nize, why is there a comparisson to a Vitesse Stage II to your car? Not to be brazen, but you're showing us data logging from your setup that is a fully stand-alone system. You aren't showing us a apples to apples in any way. What other mods do you have? You have a completely different setup than a Vitesse S2, and you're comparing turbos that are vastly different. Touting the difference between thrust bearings and ball bearings when talking about a 50trim compressor on a #10 hotside versus a K27/? on cars with different controls systems, different modifications, and different tuning isn't a valid comparisson.
Out of curiousity, however, where was that data log stored? What were the driving conditions?
#32
read the turbo review in my sig for full disclosure.
#33
jeremy; i'm not saying you're full of ****. i do know from experience that what appears to be 15psi on the boost gauge at 3k rpm (for example), can easily turn out to be 15psi at 3200rpm in reality. engine variables are changing so quickly that in-cockpit/butt-dyno analysis is really just speculation at best..
over this weekend, i met up with another rennlister who had the full vitesse stage2 setup (maf, turbo, piggyback tuning, etc.) which i understand is a k27 and we did a side-by-side comparison. the garrett dbb #10 not only spools faster but also pulls harder to redline. when he got in my car for a butt-dyno he was shocked at how big the difference was.
Your turbo is actually closer to the old Vitesse stage 1 Turbo (except for the BB).
I've heard all the stories about the holy grail GT series turbos, T3 this, Super that, blah, blah, blah. I've been in plenty of 951's over the last ten years (GT25, GT30) and I've yet to come across a 951 builds boost as quickly as mine does and can support over 400WHP. Period. Anyone who doubts it is welcome to take it for a spin and talk **** later.
#34
i'm curious because i have plans to get over 400whp/wtq soon.
#35
I have had it on a dyno and I saw 330 SAE corrected RWHP @ 16ish PSI. Have the printout at home somewhere. Not really a dyno queen myself and prefer to do a comparison with the cars moving.
You stated that you met up with a rennlister over this weekend and did a side by side comparison of your dual BB 2.7 darton sleeved turbo motor against his K27 Vitesse stage 2 and that is emperical evidence? I'll bet he was surprised. Does he have a name????? Come on, who are you kidding here......
#37
Funny because my statement was copied from your comments on a thread that you started. In case you need someone to refresh your memory.....
i really don't want to release turbine specifics, as i'd like to protect vic's research and effort, but if you ask pauer tuning, he can hook you up with the identical turbo that i have.
when i was going through my turbo options, pauer did give me full disclosure of specs. i just don't feel i need to post them here is all, because what i've posted is already way more information than what's available from any other vendor minus lindsey.
when you're ready to buy, give pauer a call and you'll see he'll tell you everything.
https://rennlist.com/forums/showthre...=352032&page=2
What's good for the goose right?
What I will say is that you've questioned everyone elses turbo as if yours is the only solution, provided a few data logs, an uncorrected dyno chart, and now a mystery guest vitesse stage 2 (K27 stage two none the less) comparison and you call that emperical evidence that yours is better? Did you mention to the mystery vitesse stage two K27 variant owner that you had a 2.7L?
#38
Back to the original question: BTDT, and my answer is YES. When I bought my '86, it had the original K26-6 with a 38 mm TiAl wastegate and Bursch test pipe. It was a quick-spooling, torquey car, but the turbo ran out of breath at 5,000 rpm. I had the K26-8 (freshly rebuilt) left over from my '89, so I bolted it on and swapped the Guru K26-6 chips for the Guru K26-8 chips.
It was a great improvement. With the wastegate and test pipe, the spool was almost identical (15 psi by 3,000 rpm), but the turbo doesn't start to run out of breath until over 5,500 rpm, and will hold 13 psi at 6,000 rpm. Equal torque and response, +40 hp. Just as good at autocross, huge improvement on the track at DE days. I get many comments on how strong and fast my car is. I know it will now consistently pull on a 400 hp C6 Corvette down the main straight at Thunderhill.
If I was starting from scratch, I would probably go K27-8 plus MAF and injectors, but if you have a good K26-8 available, like I did, I say go for it!
#39
garrett dbb center section
50 trim cold side
#10 hot side
stock bolt-on fit
can you provide the same basic information about your turbo? no? i didn't think so. why are you even posting here if you don't want to share information with your fellow 951 enthusiasts?
i've also released a side-by-side comparison between this turbo and the stock k26/8 on the same car with the same mods, and enough data logs, dyno, spool characteristics, etc. etc. to satisfy any comparison shopper. have you? no? again, i didn't think so.
and yes, the vitesse stage2 guy knew full well what all of my mods were. it turns out he had actually been following my car's history for a while.
despite all of my independent research, i'd be more than happy to switch to a different turbo if it can be proven that would be a better choice. unlike you, i'm not a blind slave to a single make/model/vendor.
let me know when you're actually ready for full disclosure and independent testing with empirical data instead of talking out the side of your *** while experiencing buyer's remorse.
#42
Originally Posted by nize
stop speculating and post up some real data.
jeremy your sig is bang on, as always.
#43
You posted the exact same stuff that's advertized on your resellers web site. Like you, I'll release exactly what my reseller does. You accuse me of being a blind slave but I know what story you bought into and the truth behind the "extensive" experience. It cracks me up and if you knew what I did you would feel like a fool. Answer one questions for me, while I can't be for sure, does your hot side picture have the PN for a #10 housing machined for a stage 2 wheel? Is this correct?
Troll on Nize....as usual.
#44
when you actually have anything to contribute to the 951 community instead of voodoo pixiedust hype with zero technical information, data, nor facts, perhaps people will take your comments seriously.
until then, have fun mud slinging and paying and talking out of your ***.
#45
[QUOTE=nize;5611651]despite all that, here is all of the information i have released;
50 trim cold side
#10 hot side
stock bolt-on fit
Quite vague...
You don't sound satisfied with what you have now.
I was considering an upgrade, but since its my daily driver, I think I'll just stick with my old, reliable, out-of-the-box Vitesse setup. It's simple, goes fast, and doesn't need all that fancy datalogging stuff.
50 trim cold side
#10 hot side
stock bolt-on fit
Quite vague...
