Catless vs 3" test pipe and catback
In my car, a bursche test pipe provided a noticeable bump in power over a stock exhaust with cat. Going from the 2.5 inch bursch to the 3 inch SFR testpipe was not as noticeable.
Originally Posted by DrZ1
This is what I expected, thanks for all responses. Next question, will the turbulance of the gutted cat be much improved by a staight pipe?
and
Which muffler would be better the stock and slightly,maybe 25%, louder then stock set up(being catless)
Thanks Again
Steve
and
Thanks Again
Steve
On my red 86 that I am parting, it has the same setup, but a flowmaster 40, which is a bit louder.
and
Thanks Again
Steve
and
Thanks Again
Steve
if you're staying with the stock exhaust plumbing, you can't beat the sound of the stock muffler. the stock muffler is already straight-through with zero restriction.
"if you're staying with the stock exhaust plumbing, you can't beat the sound of the stock muffler. the stock muffler is already straight-through with zero restriction."
My muffler has aproprox 120 miles, I guess as I bought the car w/ 97k. With this high milage, could there be collapsing/ deteroration or a reason to change?
Steve
Steve
depends on the environment i guess. the last three stock systems i've seen with over 150k miles on them were in great shape.
then i saw one with under 100k miles that had deteriorated.
the stock system is stainless, fyi. a lot of people mistakenly think it's mild steel.
I have a gutted cat and a 3 inch cat back that I picked up cheap. I keep wanting to go to a full three inch but at this point I don't think it will help much. Still want to do it though...
IPSC
IPSC
My original muffler rotted/rusted and literally broke in half at about 40k miles. I replaced it with new factory muffler and it still looks new after another 40k. Luck of the draw I guess (or more likely the effects of my car spending its youth near the ocean).
I gained 10psi at 3000rpm by ditching my cat and getting a 3" pipe. Of course my cat was so clogged that the mechanic got his scope stuck in it trying to check it.
I love the sound of the test pipe with the stock muffler on there too. It's basically a bit deeper then stock but the same kind of sound. I think it's nicer then the full 3" systems, not as loud or raspy as the ones I've heard, but I probably loose some power with it.
OK, you will see a improvement in spool up and power with a testpipe, 2.5" or 3" really doesn't matter much. Dfastest951 has over 500hp and is still using a stock sized 2.5" B&B exhaust. I have a bursch testpipe and B&B cat-back. B&B and Dansk make great stock sized fully polished cat-backs just the Dansk is half the price of the B&B unit, I wish I would have known that. Both dansk and B&B make 2.5" testpipes too. The testpipe does make the car louder and sound much more sporty. I had a some what new high flow cat and still saw an improvement in power and sound. The cat also works as a muffler so it is like deleting a muffler. The exhaust itself is also much cooler now due to the fact there is less restriction. If you live in a state where the is a lot of emission BS, like CA, then I recommend you get a lindsey racing or speed force racing exhaust since they offer a "clamp on" style cat with their 3" systems.
I replaced my original exhaust at 118,000 miles, it had a small hole right after the muffler but was in OK shape overall, even if it was ugly. I did like that it had a straight through muffler (B&B doesn't) but the B&B is still louder. I regret getting rid of the old exhaust only because I could have made a straight pipe out of it for a day at the track or when I feel like being loud.
B&B catback with bursch testpipe and crappy camera
http://youtube.com/watch?v=GXQAqCPqAd4
