Undoing Oil Cooler lines
I'm finishing up a friend's 951, and just have to replace one of his oil cooler lines, but I can't get the oil line off the housing. I've removed the oil pressure sender, but still don't have any room to move a wrench. Anybody have any tips for removing the line? I thought that a crow's foot wrench might work.
It's the line on the left.
Thanks in advance.
-Dmitry
Thanks in advance.
-Dmitry
Dmitry,
I couldn't get mine off either. I just removed the oil cooler with them attached as it had to come out. Sorry its not helpful, I believe clarks garage lists a specific short stubby wrench that can be used on that line. Good luck!
Originally Posted by Maciek
Dmitry,
I'm going to see if Sears carried a 1 1/4 stubby combo wrench, i think that may do the trick. If not, I could probably bend or cut/weld a standard 1 1/4 combo to fit.
Drop the sway bar as far as possible and make as much room as you can. I bought wrenches to fit the adapter and the oil line and squeezed them against eachother. Stubbys just can not get the torque you need. Squeezing two together with both hands broke mine free. I also leaned a bit on the hard piece, using its 90 degree a bit of the flex as another source of grip. Hose came off but adapter stayed in and could not be removed with just the wrench. I ended up blasting it out with an impact wrench through a swivel and at least three extensions. I had to get the adapter out to put a new one in as a part of an oil cooler upgrade.
Once out, I put the hard line in a vice and used a closed end wrench to try to break the flex piece free from the hard piece. I would guess it took about 300 ft lbs to break the two free. Insane.
