stock caliper + larger rotor brake upgrade??
Anybody know of a brake system upgrade that allows us to retain stock calipers but use larger diameter rotors? I've seen it done on other cars, where a bracket is used to relocate the calipers a few inches radially from the center of the hub, making room for larger rotors. Larger rotor surface area = better cooling and less fade.
I searched and found lots of info on brake upgrades, but it seems most involve newer/bigger calipers. Curious...if this hasn't already been tried on our cars, could it work and would it be considered a valuable modification? It would certainly be less expensive than installing S4 or Big Red calipers...though arguably less effective.
it's quite possible yes, just fabricate the adapter and find a disc with same offset, or adapt the fitment with caliper, you will need to find a rotor with same width of pad running surface.
usually stuff like this is done on the rear.
I don't have the time/resources to tackle this project right now...I was hoping that somebody else had already done it. I guess I'll have to add it to my list of winter projects. Either that, or petition a shop to fabricate a braket for me. I'm sure it can work...and possibly be a money-maker. Hmmm...........
Check out this link
http://www.sandher.com/Mark_Cole_BrakesMod.htm
It is exactly what a UK 993 owner has done to fit the 322mm disk from a 928GTS under our standard callipers that normally use a 304mm disk
