Jim's <Special Tool> 2.5L BIG HP Project FINALLY DONE!!! PIC & VID
#77
Originally Posted by Cory9584
He can also spray nitrous in the lower rpms to get the turbo spooled ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#78
UAE Rennlist Ambassador
Originally Posted by special tool
1 bar at 4510 on the datalogger.
4th gear, 76 degrees, level hghway, as yet untuned 10.9 spoolup afr, Mlledge 503/475 advanced 2 degrees, sfr intake/75mm tb, shortblock from Lart.
Torque is not as bad as I thought, might do 550 at the wheels - we'll see.
I know its laggy - but I will get it down to 4300 or so.
Also - this setup will run 25 psi opn pump gas ALL DAY LONG - egt's are NOTHING.
I will shoot for 500 at the wheels on pump gas.
Rememberiung you're previous set-up, you hit 397 (or so) at the wheels on 19psi on pump, yet achieved 574 at the wheels with race gas and 24-25ps, no hardware chagesi. So, gaining so much power with that crazy advanced timing of you'res, i would not be suprised if you get 650-680 at the wheels on race gas and you are aiming to run over 25psi on race gas as well right?
#80
Originally Posted by Trucho-951
Or... do it Lancia style, I believe the Lancia Delta S4 back in the 1980's used a combination of supercharging with turbocharging to reduce turbo lag at low rpms.
j/k
oh, going real OT, just found this great youtube vid on a modern 1.4L TSI engine dualcharging system..
http://www.youtube.com/watch?v=Pdp5i...elated&search=
#81
Originally Posted by hosrom_951
If you are ale to get 500 at the wheels on pump, then you should have no problem getting over 600 at the wheels with race gas.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#83
I'll have the videos soon.
Sunoco 2 miles from my house just started selling 100 at the pump, life is good.
The owner says to me, "we sell to Fahrenbacher/Lowles"
I said, "oh, that means you have to deal with Spencer, sorry to hear that"
He says, "Spencer's not THAAAAAT bad......"
Some of you local guys know go-go "sunglasses" Spencer.
#84
![order](https://rennlist.com/forums/graemlins/order.gif)
