delete please
I'm doing an oil cooler seal replacement and per Clarks instructions i am to use grease to hold the main gasket to the housing as i install. My question is, should i be greasing both sides of the gasket to lube and hold, use grease on the metal portion of the gasket to hold and leave the gasket dry or use grease on the metal to hold and oil on the gasket to lube. thanks.
