My Saikou Michi catch can install UPDATED PICS with correct hose routing.
Old 05-26-2007, 04:54 PM
  #46
ehall
ehall's Avatar
Originally Posted by gregeast
Sam, looks good but isn't that going to be kind of a long run for the hoses back to the intake?
OT: Is that a wee little bit of wax down in the fender next to the headlight cover? And here I thought your car was always perfect, LOL!
Greg, you ARE aware that your OCD is now considered a "medical condition", right?
Old 05-26-2007, 08:14 PM
  #47
gregeast
gregeast's Avatar
I forgot to take my meds today but I'm hoping the beer will compensate. You really ought to try it at 5k feet sometime!
Old 05-26-2007, 11:33 PM
  #48
ehall
ehall's Avatar
I forgot to take my meds today but I'm hoping the beer will compensate. You really out to try it at 5k feet sometime!
hELL, 5K WON'T EVEN GET YOU INTO THE MILE HIGH CLUB!
Old 05-27-2007, 12:06 AM
  #49
gregeast
gregeast's Avatar
No, but the beer might...
On topic: I'm anxious to see if this catch can will really cut down on the oil in the intake tract.
Old 05-27-2007, 12:16 AM
  #50
ehall
ehall's Avatar
That's why I'm following this thread.
Old 07-20-2008, 07:13 PM
  #51
ehall
ehall's Avatar
bump. Someone was looking for this recently. Here it is.
Old 07-21-2008, 12:59 AM
  #52
nize
nize's Avatar
i recently bought one of these, but i'm having second thoughts about installing it. mainly because you can't take it apart to see if there's any gunk caught inside (after a period of time).
also, a buddy had the lindsey crank breather, and when he installed the oil pressure relief valve incorrectly, resulting in coolant entering the crank, we were able to immediately tell what happened because coolant was coming out of the crank breather (due to it venting to atmosphere).
that got me thinking if this closed system was installed, coolant would have entered the intake/pistons, resulting in possible bent rods.
so i'm still debating wether i should install this or sell it.
Old 07-21-2008, 01:02 AM
  #53
ehall
ehall's Avatar
"also, a buddy had the lindsey crank breather, and when he installed the oil pressure relief valve incorrectly, resulting in coolant entering the crank"
Umm nize, just don't do what your buddy did!
  #54
944CS
944CS's Avatar
I would install a vacuum pump of some sort running to a catch can venting to the atmosphere so there is no vapor whatsoever entering the intake and also keeps a consistent level of vacuum in the crankcase
drag racer's have been doing it for years
Old 07-21-2008, 01:03 AM
  #55
ehall
ehall's Avatar
also, see ST's input on this. You'll find more in a search.
Old 07-21-2008, 11:36 AM
  #56
gregeast
gregeast's Avatar
Saw this resurrected thread and realized that I hadn't posted any pics of how I mounted mine. I had some aluminum stock that I cut to fit, using the same design as Kevin. BTW, I drain it every couple of months, it doesn't collect a whole lot of volume but what's in there is pretty gunky.
Old 07-21-2008, 01:24 PM
  #57
IPSC
IPSC's Avatar
As for "Seeing" what gunk is in there, the drain on the bottom opens up and the gunk drains out. In addition I wash mine out with hot soapy water every six months like the manufacturer recommends. Easy to do with it mounted up front.
Greg, nice job (as ever) on the install by the way.
IPSC
Old 07-21-2008, 02:32 PM
  #58
nicco
nicco's Avatar
and here it's mine
Old 07-21-2008, 02:54 PM
  #59
MAGK944
MAGK944's Avatar
Nice work!
Funny, that's what I use mine for too:
Old 07-21-2008, 11:35 PM
  #60
lleroyb
lleroyb's Avatar
Nicco, how about starting a new thread describing your modifications. Very nice workmanship. I am most curious about your coil set up and who's blow off valve is that and what controls it?
Lou
Quick Reply: My Saikou Michi catch can install UPDATED PICS with correct hose routing.
