What should I do next to pull engine?
05-22-2007, 01:42 PM
Quote:
Originally Posted by lejams
Can you safely lift it using the tow hook?
Without the engine it is not a problem.
05-22-2007, 01:49 PM
Drop it from the bottom, it's easier to do. No need to remove those radiator fans. We just dropped friends 951 engine few hours ago.
05-22-2007, 02:03 PM
Quote:
Good, I'm planning on using Skip Wolfes write up. I only have one lift, so I was hoping to drop the engine, then lift the car with the same hoist. Haven't swapped an engine in 25+ years and it was easy on a 62 pickup. This should be fun
Quote:
Have any details/tricks to add?
05-22-2007, 04:34 PM
I have always remvoed the fans. More space and the fans are held on by 6 bolts so the come off in 5 minutes.
05-23-2007, 01:20 AM
So you jsut screw in a tow hook/big *** bolt and it will be strong enough to pick it up?
05-25-2007, 04:12 PM
hey jace, i just helped another local 951 guy drop his motor. we finally got it out on tuesday by ourselves. let me know if you need help.
