Difference between years - DME/KLR?
Going with the pack
is quite monotonous.
Might have a problem with one of my boxes.
'88S.
Other than chips, can I use any 87+ DME or KLR?
'88S.
Basic Sponsor
Unaffiliated
I have an 89 T DME and a 87 T DME, and they are both fine in my 89 T as long as the right chips are installed.
Basic Sponsor
Originally Posted by Zuba951
Can you use an "S" box on an 86 if you change the chips?
Brian
86 951
Brian
86 951
TIA
lart
You can use turbo S DME on a 86 turbo if you have in that DME box a '88 non S chip. All boxes can be used on all models if you use right chip. Early boxes can easily be modified to have a 28 pin chip
Unaffiliated
I've taken an 89 T box, with an 89 T chip, and put it in a 87 T and it drove fine. I'd suspect the fuel maps might be a tad off (due to turbo size?) but it worked fine for us.
Originally Posted by lart951
does anybody know if you can use the turbo S dme on a 86 turbo?
TIA
lart
TIA
lart
IPSC
