Lindsey Steam Vent kit
If more people want pictures of the steam vent kit hole, I have my head off in the garage with the hole drilled out (fresh from lindsey) and I can take pictures of the hole and pipes it comes with.
Originally Posted by dlr944
What convinced you the steam vent kit will work?
Oh yeah! The one thing everyone agreed was good about the steam vent kit was that it automatically bleeds any air out of your cooling system. If you have one you don't have to bleed air out manually. The general consensus in another thread was that the $40 kit was worth it for the self-bleeding capability alone, much less any coolant benefits. Of course it makes it a lot easier to drill the hole with the head off.
As per requested, here are some pics of my head with my sophisticated measurement system.
In the one that has the hole traingulated with the square (pic #3), I was trying to hold the bottom edge of the square as parallel to the intake-mounting edge as possible.
Pic 4 has the bottom of the square sitting on the edge of that blocked passage, or whatever that is, so the measurement to note is from the lip of the blocked passage to the center of the hole.
Pic 5 is showing the hole through the water passage next to cylinder head. Everyone can feel free to oogle the o-ring in the pic.
Originally Posted by Laust Pedersen
Assuming air is trapped in that end of the cylinder head someone has got to ask the obvious questions, so here we go:
1. Why not just install a purge screw there? Once purged, air should not mysteriously re-appear.
2. Or maybe it is fully adequate to tilt the car by driving the front up on a ramp and then purge from the front? … after high rpms in that position (to chase the air to the front).
Laust
Laust
read this;
http://www.turbo944.com/bbs/config.cgi?read=1068
and this;
https://rennlist.com/forums/showthre...54#post3756254
Originally Posted by nize
the steam bubbles re-appear every time the piston walls get hot enough to boil the coolant at the back surface of the walls. eventually, an 'air cave' will form at the back of the motor, regardless of how well you've vented the coolant.
read this;
and this;
read this;
and this;
As I learned and Pauerman pointed out, some (probably the early) Cometic MLS gaskets have almost no transfer holes to the cylinder head in that area, which would make things worse.
Laust
