RennSpeed Racing - New products, new prices - check it out!
Set to Full-Auto
First up, I have a couple new products - those of you familiar with the hatch pins will recognize the first one.
http://www.rennspeedracing.com/ss_hood_pins.html
It's of the same construction as the hatch pin as far as machining and material. It replaces the factory hood hold-down pin that is nasty looking with a shiney new stainless one that will never rust.
The second thing is not that big of a deal, but still wanted to throw it out there.
http://www.rennspeedracing.com/tshirts.html
I had some t-shirts made for myself to wear to track events/meets so people could identify me as that guy from RennSpeed. I made a whole bunch of them to get the price down and they turned out better than I could have imagined! Testarossa_td did the artwork, every where I go I get compliments on the design.
Also, I changed the we I manufacture my various stainless studs - for the better. I was able to put together a tool to broach the hex key on the lathe as well as began using a different stock size..........what this all means is that I was able to eliminate a lot of time and waste material. This makes it less expensive for me to manufacture, and I am passing those savings strait on to you. I have also phased-out the non-broached studs. I didn't have very many left in-stock and now that it's just as easy to produce the broached ones........they became obsolete.
http://www.rennspeedracing.com/ss_exhaust_studs.html
http://www.rennspeedracing.com/ss_manifold_stud.html
Set to Full-Auto
I don't know - they are strong enough, if you blow/break your intake manifold off........you have other problems at that point........
The reason I made them was to make installing the intake/gaskets easier.
Set to Full-Auto
Dude, look closer.
I actually discontinued the non-broached exhaust studs.
Broached ones are the ONLY ones I sell now..........
Originally Posted by Porschephile 924
can you make a panacea that makes changing a 951 clutch easy?
Really love the design of the shirts! if demand or interest goes up for them, will you be making different sizes, becaues I see only XL is offered....Large would fit me well THANKS
Set to Full-Auto
I have maybe one or two larges left (only made 10, not enough to list on the site). I will be making more sizes as time and cashflow permit.
Paypal me $15 to sharky-47@excite.com with your shipping address and I will get a large sent to you.
Could you machine me a set of ft wheel bearing dust caps to work with my 996tt wheels without using spacers? I understand one-off stuff is expensive but thought I would ask. Thanks
