Toasted injectors - why?
Check the injector pulse to make sure one of the injectors isnt staying on. You can make a tool to do this from a lightbulb or test light. Are there any signs there was a fire that melted the injectors at one point? Or was severely overheated?
the tps in virtually all bosch fi systems lets the computer/dme know if you're idling/emissions, or accelerating or decelerating.
if it's unplugged, the vehicle still runs but doesn't accelerate as well, assuming it's adjusted properly and tested with an ohm meter for opening/closing, the clicking.
87951
87951
Originally Posted by sweanders
229000 km's.
My plan is to swap parts with another 85 951 until I found the error. Unless the compression test tells me something I don't want to know..
Anders, I had a similar problem when my wiring harness was junk. Cut back the boots on a few of the injector connectors and see if they are shorting out. I burned up one set of injectors and couldnt the car running correctly and that was found to be the culprit.
Originally Posted by Driftomagnifico
Pull the PCV, see if you have alot of blow-by or air coming out of it.
Cracked ring land would pressurize the crankcase on combustion.
