Test pipe gasket question
I searched on this one in the archives and think I'm all set, but I just want to make sure that I have it straight.
I bought a used Bursch testpipe from a lister that I just had Jet Hot coated. I have the wastegate tie in clamp/crush ring covered, but on the gaskets that go on either end of the testpipe (i.e., between the downpipe & testpipe and the muffler pipe & testpipe), can I use the copper gaskets that paragon sells?
http://www.paragon-products.com/Prod...Code=FS951GAS3
These are for a 3" exhaust rather than my stock size, but I assume that the flanges are the same and therefore these gaskets should work fine, right?
The alternative, as I understand it from searching, is to either:
A.) Buy a gasket sheet or copper sheet, make a template, and cut my own gaskets with tin snips and a 2.5 inch hole saw
or
B.) Buy generic hot rodder gaskets that are similar and modify the holes as required to accomodate the Porsche spacing
I'm kind of inclined to be lazy and just buy the gaskets from Paragon, but I want to be sure that these will work with the Bursch pipe. Also -- is there a crush ring of any sort between the catpipe and muffler pipe that attaches to the muffler pipe, or is this simply a gasket?
or
Was that the gaskets at the bottom of this link: http://www.lindseyracing.com/mm5/mer...951EXHAUSTMISC
These are actually the exact same pictures as the ones in the paragon link. I think they're made by Fabspeed? I guess that I just need to order these two and be done with it?
Yep, those copper gasket will work fine -- and they are re-usable. I used them with the Bursch pipe, and now with the 3" SFR pipe, with no problems.
