Cleaning the Engine Compartment
1 Post
castrol Super Clean works well in the engine bay. I would avoid using cans and can of brake/carb cleaner in the engine bay and stick to a non petroleum solvent. Remember, some solvents work well on metals, others on plastics and others on paint. Another option is to take it to a detail shop and have it steam cleaned. It does not cost much and the results are perfect. just tell them where not to clean. In fact, I think it is well worth the $30-40 to have the under carriage cleaned before doing a motor, clutch or trans. I have an appointment to have the bottom of my Chevelle cleaned on Wednesday.
1 Post
I had the underbody steamed cleand and it was wonderful for my rebuild. I would adivse against having the engine bay steam cleaned, because the solvent in the steam was to harsh for the aluminum.
Location: Laguna Hills, Southern CA 88 turbo s silver rose
aww and the steam clean was sounding like a cheap alternative too
no shortcuts i guess for anything
I just taped plastic bags over some parts, sprayed a bunch of GUNK engine brite, let it sit, then took some brushes I bought at the dollar store and scrubbed away. I hosed it off and then repeated it 2 more times. Ive been meaning to do it again.... I dont work tommorow....maybe I'll post some pics
I recently cleaned my engine bay and I used a marine aluminum cleaner. I had the intake powder coated and some other parts including the fuel rail zinc coated but I haven't installed those yet.
THIS IS NOT MY ENGINE (i have a NA so itll be a lil diffrent for you)
![](http://i171.photobucket.com/albums/u301/The_Jerks/perfor4copy.jpg)
Just get the coverd parts with the brush and rag. Wipe down the plastics by the windshield with a rag too. I think I am going to clean my engine tommorow. Ill post pics on this thread then
