where to have a K27/8 built?
Wax On, Wax Off
guys, I'm pondering having my dead K26/8 rebuilt into a K27/8. who should I look into having do this conversion, and what sort of costs can I expect in such a conversion? thanks!
I've heard good things about these guys:
http://www.blouchturbo.com/
If you make it faster than mine...I'll punt you off the canyon roads.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
I have had my turbo done (twice) by Majestic Turbo. Great Q, quick turn around (2 days)
Typical upgrade cost $695.
Wax On, Wax Off
If you make it faster than mine...I'll punt you off the canyon roads.![nono](https://rennlist.com/forums/graemlins/nono.gif)
if you can catch me that is...
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
UAE Rennlist Ambassador
Originally Posted by nize
since it costs $700+ for a rebuild, and you can buy a brand new one for $900, i have to ask why would you want to choose the rebuild route?
the question still remains, as a brand-new turbo in that range still goes for around $800 vs. rebuilding for $700;
http://www.034motorsport.com/product...products_id=43
and;
http://www.034motorsport.com/product...products_id=49
and;
Wax On, Wax Off
I'm revisiting this thread... What would be needed if I had my turbo rebuilt into a K27/8? I understand I'll need another J-boot (possbly N/A?) and and adjustable FPR... I assume my chips from Vittesse for the K26/8 will be no good, so I'll need new ones there.. what else?
Yep, you'll have to modify the J-boot. At one point I had an NA boot (before I went with the MAF) and it would have fit the larger diameter of the K27 but as I recall I was going to have to do some monkeying around to get the necessary ports for all the stuff attached to the J-boot. And yes, your maps will be wrong on the chip so you'd need John to reburn them for you.
All that said, based on the research I was doing before I had my K26/6 converted to the K27/6 (Turbo Performance and no, not a good idea...) the consensus seemed to be that a K27/8 was going to be pretty laggy, made worse of course by being at 5k feet. My K27/6 can hold 16psi to redline and spools up at about 3200rpm, just for comparison. You're more than welcome to drive it anytime. And I have a k26/6 that I inherited that you could use for the conversion if you decide you like it...
