Head gasket triva - Pics
Can you name the cause of this head gasket failure:
Specs:
Wide Fire Headgasket <5k (yr 2005)
SIII Vitesse Kit
Rebuit head by Peformance Developments <5k (yr 2005)
Runs 12.5:1 on WOT (dyno)
Factory studs
The fire ring, on the #4 cylinder head gasket, looks compressed but the water jacket edge is bludged?
Appreciate your thoughts on the culript?
thanks
Specs:
SIII Vitesse Kit
Factory studs
thanks
Basic Sponsor
Specs:
SIII Vitesse Kit
thanks
Specs:
SIII Vitesse Kit
thanks
Originally Posted by KuHL 951
Did you reuse the existing head studs?
UAE Rennlist Ambassador
Originally Posted by lart951
12.5:1 IMHO is way too lean, what you got there is the result of detonation, what boost level are you running? I personally like to run 11:7 - 12:1 at 18psi and 11:3-11:7 @ 21psi.
Anything under 12.0 is rich, i even saw 13.1 on boost (3,000-3,300rpms) for the sake of hotter exhaust gases, effecing in reduced spool, then a rich 12.0 in mid range for torque and then a solid 12.5 till redline for power.
At least, that is the way i like it.
Yes, I re-used the factory studs and marked the tops to ensure they did not turn when tighting the head down.
That Guy
Thats why your head gasket went. porsche head studs suck after retorqueing them... ask me how i know
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Originally Posted by TurboX
Thats why your head gasket went. porsche head studs suck after retorqueing them... ask me how i know ![grr](https://rennlist.com/forums/graemlins/cussing.gif)
The other interesting point to make is the #4 cylinder's water passage is damaged in many of the 951 headgasket cases?
Hey Man
Formula One Spin Doctor
That head gasket shows detonation damage ,typical for the no .4 cylinder..
stonger headstuds would have had the fire ring being damaged also , as the head would not have lifted enough to produce the damage behind the fire ring ..
Thanks!
Basic Sponsor
Any thoughts on why the #4 cylinder is the short fuse? Why is this typical...?
Thanks!
Thanks!
To put my previous setup into contrast I use 21psi daily for the last 3 years, I have ran up to 23psi and my a/f ratio has gone as high as 13:1 for a second but I also used 10-20% xylene depending upon boost level. But I have a different block and head also.
Ouch that sucks. Another project to add to my list. 120k and I think its got the stock HG. Will be interesting to see how it holds up once my car is boosting properly.
