Sluggish Wideband Response
Old 04-24-2007, 11:44 PM
evil 944t
evil 944t's Avatar
bump, I updated my ^ thread.
Old 04-25-2007, 12:21 AM
Red1
Red1's Avatar
Originally Posted by evil 944t
update, they also said when the o2 goes bad, it will also get frozen @ 14.7. So try swapping it out with a good sensor and check the connections.
Yep. Exact same thing happened to my Uego.
Old 04-25-2007, 12:25 AM
333pg333
333pg333's Avatar
Thanks for following this up Dave and keeping us all informed.
Old 04-25-2007, 12:36 AM
evil 944t
evil 944t's Avatar
No problem. Let me know what you find. Maybe we can get them to warrenty your sensor?? I asked them, we'll see what they say..
Old 04-25-2007, 09:14 AM
kasturbo
kasturbo's Avatar
Do you have a phone number for them Dave? I've tried three emails and they won't respond to me. I'm trying to figure out what sort of waranty if any these things have.
Old 04-25-2007, 09:30 AM
evil 944t
evil 944t's Avatar
No, they don't list one but this is the email address I used and they got back to me fairly fast.
sales@zeitronix.com
Old 06-02-2007, 03:09 AM
333pg333
333pg333's Avatar
Just to dig this up again. Did those that were having difficulties find a remedy to the problems. It would seem like the O2 sensor is the main culprit. Bit strange mine would go after only 4 days? Is 14.7 where is defaults to at idle? Mine got stuck there. I just need to fix this before my upcoming re-re-assembly. Any ideas are gratefully received.
Old 06-02-2007, 10:32 PM
333pg333
333pg333's Avatar
Bump. No-one had any more issues or solutions?
Old 06-02-2007, 10:35 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Mine just seems to do it once and a while now. I assume it's either the sensor or the zeitronix box. The zeitronix also fails to boot about 1 out of 10 times, so it may be going south...
Old 06-02-2007, 10:39 PM
333pg333
333pg333's Avatar
Well i've just emailed the sales desk to see what they suggest. Mine worked for 3 days and then just froze on 14.7. Is that a default number as some others have said the same number with their problems? However it coincided with a piston sort of 'freezing' on a 4 day rebuild so I haven't any use for the zt2 a.t.m. but in a couple of weeks time when we get some decent pistons/rings we will need the Zt2 to tune so I'm not sure whether to just buy a new o2 sensor as it seems the most likely culprit, or take the whole thing out and send it back to Zeitronix to inspect?
Old 06-03-2007, 02:53 PM
kasturbo
kasturbo's Avatar
I ended up replacing the sensor and that fixed my problems. I think I toasted the sensor last year running leaded fuel.
Old 06-03-2007, 03:15 PM
theedge
theedge's Avatar
Yes leaded fuel is very hard on O2 sensors in general, and even worse for wideband sensors.
Old 06-08-2007, 07:15 PM
DLS
DLS's Avatar
my zt-2 has also died
rpm and tps is working fine but afr is stuck at 14.7 and lambda at 1.00
my zt-2 is only 2 month old.
Old 06-11-2007, 05:34 AM
DLS
DLS's Avatar
333pg333 have you fixed yours?
Was it the sensor?
Someone told me that the sensor is shot due to mutch heat and that i should do a heat shield around it.
What do you think?
Quick Reply: Sluggish Wideband Response
