Preferred Replacement hood liner?
Chainsaw
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
When my hood was repainted, top and bottom, and the new heat sheild was installed, it was less than $50.00 from Porsche, even with the body shop mark-up.
Originally Posted by sweanders
It was skipped on later versions, IIRC the hood liner is only there for sound insulation.
Ha ha ha, almost $100 for the paragon foil once you pay shipping?! Do yourself a favor and go to Home Depot and buy a roll of the foil faced insulation and cut your own liners. For $25 you'll get enough to do 2 maybe 3 cars.
resident n00b
I'm in the process of removing the remaining adhesive from my liner.
What a PITA. This is how much progress i made in an hour.
I'm using OOPS Adhesive remover & a plastic paint scraper.
There may be a better chemical out there, but this one isn't damaging the paint so i happy with it. You just have to let it soak in for a few minutes before you start scraping.
Originally Posted by Tom M'Guinn
What are the part # ?
TIA
Stock replacements look nice...
http://members.rennlist.com/tom8695..._installati.htm
Are they OEM pads ?
TIA
Are they OEM pads ?
TIA
TIA
Originally Posted by RKD in OKC
Saw hood liners on ebay with Porsche emblem on one.
http://emartshops.com/The_928_Leathe...t_Shields.html
