968 Oil cooler?
Old 04-14-2007 | 03:29 PM
IPSC's Avatar
IPSC
Default 968 Oil cooler?
Has anyone added a 968 oil coller to the 951? if so how did you go about doing it? I have an 89 and want additional cooling. I can pick up an oil cooler off of a wrecked 968 cheap.
IPSC
Old 04-14-2007 | 07:01 PM
GeorgeNZ's Avatar
GeorgeNZ
The 968 cooler has different fittings on both the cooler and the oil plate. Go where others have gone before and use the KISS setup.
Old 04-14-2007 | 08:18 PM
IPSC's Avatar
IPSC
Oh I thought about this but I have access to people who make hydrlics lines so getting the fittings and hoses made will be nothing. I was just curious if anyone had done this and wanted to know what kind of mounting solutions had been come up with.
IPSC
Old 04-14-2007 | 09:28 PM
reno808's Avatar
reno808
IPSC
I know they do 2 951 oil coolers. THats what iam doing.
Old 04-14-2007 | 09:44 PM
IPSC's Avatar
IPSC
I have been looking for a second 951 oil cooler to run upside down on the other side but this came along so I am trying to make this work.
IPSC
Old 04-15-2007 | 03:32 AM
GeorgeNZ's Avatar
GeorgeNZ
modern coolers are more efficient (both thermaly and pressure differential) so not much point in trying to use a 951 or 968 cooler if you're after real cooling performance. At least the 951 cooler has threaded fittings even though its oriented the other way to the 968.
Old 04-15-2007 | 02:15 PM
RajDatta's Avatar
RajDatta
You will need to swap our entire oil filter housing to be able to run a 968 oil cooler. The oil cooler is bigger than a 951 cooler and uses O'rings for sealing on both lines. So, you will also need oil lines. Also, there is some ducting work in a 968 body to force air into this oil cooler which not be the case in a 951.
So, you will need cooler, oil lines and oil filter housing.
Raj
Old 04-15-2007 | 06:33 PM
IPSC's Avatar
IPSC
My thoughts are to simply run it in series with the stock oil cooler and mount it in front of the Radiator. I can get the hoses made for me so that isn't the concern. I am just wondering how to fab some brackets to hold it in place.
IPSC
Quick Reply: 968 Oil cooler?
