Cheapest way to fix a broken exhaust manifold stud?
I found a broken stud between headers 3 and 4, on inside part of four. The stud is broken and the nut is loose. When I drive it hard, I smell the fumes coming out, nothing major, but not pleasant. What is the best way to fix it or band aid it without spending too much money? My mechanic said to get a stud anchor, whatever that is. The tech at German performance said I have to take the engine out to drill it, not going that route... any suggestions??
Set to Full-Auto
Ok, you DO NOT have to remove the engine - at worst you have to pull the head.
Is the stud broken off below the surface of the head? If no, you can grab it with vise grips and turn it out - we've done that before here at the shop. If it is broken below the head, you *could* use a right-angle drill to get at it, but that would be chancy.........
You don't have to remove the head or the engine. I broke one last year and fixed it in the car..though it does take some careful work. Buy a 90 degree air drill like this one:
http://www.yardstore.com/index.cfm?a...38&Category=10
Using a mirror you CAN get in there to drill it the center and pull it with a standard backout. I have done it myself, so I know it is possible. It helps that I already owned the drill....but pulling the head will cost you about the same as buying the drill....your call.
I think the stud is broken cause I can pull it out with no problem, I turn it clockwise so it won't fall out and tighten the nut on it just hand tight, but of course it loosens up when driven. I wonder if Home Depot has this drill, maybe I could buy it and return it???
Originally Posted by sharky47
Wait a minute - you can pull it out? Is it whole/intact, or is it a broken peice?
I had the same problem on mine 3 months ago, you must have noticed some turbo lag or some downgrade of perfomance. Yea, I remember the fumes. Later on when you get a chance, change all the exhaust manifold studs as this may occur again. Listen to sharky. Good luck.
