turbo failure
Old 04-09-2007, 09:39 PM
  #46
special tool
special tool's Avatar
Nize - I don't think they were loose for a while.
I'd say a few tenths of a second.
Old 04-10-2007, 03:33 AM
  #47
nize
nize's Avatar
the question is; how did the hot side turbine fit through the hot housing? normally the turbine blades are too big to fit through the opening leading to the downpipe.
Old 04-10-2007, 05:51 PM
  #48
nize
nize's Avatar
i just got a quote for the rebuild on this turbo to bring it back to like-new condition and one year warranty.
k26/8 turbo rebuild $694
should i do it or should i trash it? would anyone want to buy this turbo from me after the rebuild?
Old 04-10-2007, 06:06 PM
  #49
Imo000
Captain Obvious
Super User
Imo000's Avatar
Sell it as a core to someone that watns to rebuild their own. It will save on the down time.
How can they make is as new when the turbine blades machines some of the housing off?
Old 04-10-2007, 06:12 PM
  #50
nize
nize's Avatar
i don't know, but it's a reputable kkk-authorized shop and it does come with 1year warranty. they will basically replace all internals with brand-new kkk parts. i'm not sure enough housing material was actually removed to make any difference.
Old 04-10-2007, 06:35 PM
  #51
2bridges
2bridges's Avatar
I suspect you are getting a new-used housing in that price.
Tough descision. That is a good chunk tword an aftermarket turbo, but then you open the upgrade can of worms. To really get optimal benefit from new turbo, you need more fuel, MAF, injectors, chips, pigyback controller, etc, etc, etc, next thing you know your turbo upgrade is a $4k ordeal.
If you were 100% satisfied with stock performance - then why not just have it rebuilt and be done with it.
Old 04-10-2007, 08:05 PM
  #52
nize
nize's Avatar
i already have the wolf3d standalone ems, bigger injectors, etc. it looks like i'll be upgrading the turbo to aftermarket.
Old 04-10-2007, 08:15 PM
  #53
2bridges
2bridges's Avatar
cool, no brainer then, take that rebuild number ad $500 to it and go for turbo of your choice
Old 04-16-2007, 06:00 PM
  #54
nize
nize's Avatar
update:
removed the head and hand-cranked the motor. it turns, though there's a very slight bit of resistance in places, which i'm assuming is normal as the cranks need to push the pistons up. TDC across all pistons appear to be identical, at least visually and by feel. no funny noises, and the crank really is pretty easy to turn by hand so i'm hoping there's no rod/bearing damage.
the head is in the machine shop today being cleaned and checked for straightness (it should be okay). i should get the head back tomorrow.
the widefire head gasket did not blow.
a new custom plug-and-play upgraded turbo with the garrett dual ball bearing center cartridge is on the way.
expecting to make 350whp/wtq with full boost at 18psi by 2700rpm. i guess we shall see.
Old 04-16-2007, 06:44 PM
  #55
5speed300
5speed300's Avatar
Is your head O-ringed?
Old 04-16-2007, 07:10 PM
  #56
nize
nize's Avatar
head is not o-ringed.
Old 04-16-2007, 07:34 PM
  #57
Cory9584
Cory9584's Avatar
I say scrap that turbo after what its been through.
Old 04-16-2007, 08:47 PM
  #58
Rob
Rob's Avatar
What are the specs on the turbo and who did you get it from?
Old 04-16-2007, 10:55 PM
  #59
nize
nize's Avatar
it's a custom turbo from vic at pauer tuning. i will post full details and specs after it's running, accompanied with tuning datalogs and dyno graphs;
http://www.pauertuning.com/turbos.htm
Old 04-17-2007, 07:03 AM
  #60
Rob
Rob's Avatar
The reason I ask is because I have a duall ball bearing 50 trim/#8 and I don't get anywhere near that kind of spool up with it. Mine is more like 15 psi @~3k and 18 @ ~32k (non data logged numbers for now).
Quick Reply: turbo failure
