Can someone help me out with Innovate WBO2
I have the LC-1 hooked up in my car and have it wired to my MAfterburner. The Mafterburner has 2 WB wires (input/ground) The input is connected to the brown wire (WB output) and the black is grounded to the block.
The LC-1 will not give correct A/F measurments and will even start heat cycling agian once the car is running. SOmetimes it wont stop. just keeps blinking.
ANyone here running the LC-1? if so can you tell me how you wired it? and where your ground points/power are from.
TIA
-Jace
TIA
-Jace
Temprarily Banned per IB
LC-1 analog #2 output to mafterburner input. Calibrate with sensor out of the exhaust system. The analog #1 output is narrow band compatible.
Regards,
Russell
Regards,
Russell
Analog # 1 = yellow wire
Analog # 2 = brown wire
I have it hooked up to brown wire. I took out O2 sensor yesterday, let it hang in free air then calibrated. Then unhooked the sensor to re-install and torque down. can you not detach it while reinstalling the sensor?
the LC-1 was hooked in the whole time. just not powered on.
when I first installed it I would get O.K. read outs. THen it would start blinking and bounce from 10.0 to 19.8. no other numbers.
where is the best place to ground? I have one on the bolt connected to the motor lift point (rear of head) and one to the bolt holding the fuel rail to the head. are those ok?
(innovate recommends grounding heater sensor and analog grounds at seperate locations on the same ground (ie. seperate bolts on motor, or 3 inches apart on frame)
UAE Rennlist Ambassador
Yeah I did the start up stuff about a week ago. I followed it step by step and it did exactly what it was supposed to do. Ecept when I began to actualy use the device (connect to laptop, connect to mafterburner) it never read correctly, and would NEVER connect to my laptop. UGH!!!!!
