Cooling fans won't turn off
I never notice, anyway
I went driving around the state Friday and noticed that the cooling fans weren't shutting off. Well, lo and behold, my car battery was dead this morning. I went to jump it, and after I tried the first time to start it (didn't have enough juice yet), the fans kicked on and wouldn't shut off even 5 minutes later. So in order to keep my car from killing my battery I've had to pull my cooling fan #2 fuse once I got to work. Any idea what might be causing this? Bad cooling fan relay?
Thermo switch -- the little sensor that lives in the driver's side of the radiator and has three wires going to it...
They die -- you can also pull the relay as a semporary "switch" instead of the fuse.
if only one fan was running continuously, it is the relay. I have had three go bad in the last two years. they are not inexpensive, but way easier to change than the thermo switch. unless of course you enjoy coolant in your eyes and armpits. the factory warranties them for two years, so i got one free.
Do the test located here: http://clarks-garage.com/shop-manual/cool-01.htm to see which is defective. It saved me some cash as I originally thought it was the relay. Good Luck.
