fuel leak, may need parts...
Hey,
My dad discovered a fuel leak and is worried about it. At first I thought it was the typical 90deg hose on the fuel rail, but instead its one of the main fuel lines that runs down into the fender. It's leaking where it connects to the vacuum servo (I forget what it is exactly) between the 1 and 2 cylinders. Anyone else had this leak? Is it just a tighten up fix? How much are those lines new?
-Darwin
-Darwin
most people replace with lines like lindseys on their site http://www.lindseyracing.com/Merchan...=944FUELLLINES
Is it leaking at the rubber to metal crimp connection or metal to metal connection? If it's where the rubber meets the metal take the line out of the car. Using a chisel or snips, cut back the crimped area (both ends) and remove the crimp wrap (leaving a barbed stock fitting). Remove the hose, buy new hose at Napa (fuel injector hose, not fuel line) and fuel injector clamps. Slide the hose onto the stock fittings and use the clamps. Wrap with fire wrap and for $30 you have injector lines far better than those rice rocket steel braid imitations sold at vendors. Not to mention you are not using the cheap hose clamps the braided lines come with (and should be illegal).
Of if you really want the Lindsey lines..send me a PM. I'll sell you the set I bought....I refuse to put that on my car, and Lindsey's return policy being what it is....I never bothered to return them. I thought I may use them on a lawn mower or something.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I'm not a big fan of cutting the metal fuel lines in order to install a pressure fitting in the wheel well. I understand their thinking, but I don't believe it is necessary. The stock lines don't fail at the threaded connection and leaving it in the engine bay protects that joint better in my opinion. Also, having bought (way back when) a bunch of huntley equipment...I'm left high and dry should it fail now that they are gone. Buying into a fuel line setup which modifies the stock lines could lead to the same should Lindsey not be around in 5 years (long shot but it could happen).
The main reason I won't install them is the line that connects to the FPR is connected using a simple hose clamp. That clamp is not strong enough to put a serious squeeze on the steel braided line without stripping. You can still rotate the line by hand, which means it's not very tight and that is a potential leak. Any clamp, forced to squeeze steel braid and rubber beneath it...is not going to fair well in my opinion. Selling a standard zebra coolant hose clamp with a fuel injected line kit is nothing short of crazy. Ok, maybe several years as an R&D automotive engineer for Daimler Chrysler has made me always look at the worst case...but engine fires suck. Been there...not fun.
I'm not talking smack about Lindsey, I think some of their products may be useful but this one...I do not like. Just my humble opinion...worth what you've paid for it. :-)
Small Business Partner
Bill, I understand your thinking on the return line. However there should be almost no pressure associated with that line. I've had my fuel-pressure up almost 90psi pushing the limits of the stock injectors, and I have yet to have single leak.
Rogue
Rogue
Those rennbay ones look like a better solution to me than the stainless lines sitting in my garage. Keep in mind, when the stockers fail..they do so because they are 20 years old...not because they are a terrible design. No need to re-invent the wheel here....only tweek its spokes a little. Remove the crimped connections, keep the barbed fittings and use a good clamp (t-bar, fuel injector clamp etc). I like to wrap them in fire braid too...but that's the pilot in me talking.
Fire is bad...mkay.
Fire is bad...mkay.
I’ve been running and putting these together for years now and haven’t had a single one leak and most of them have been taken on and off several times. This is the best system on the market and in this case you get way more then you paid for compared to the factory replacement alternative. I can build a set for $80 and pick up all but one of the parts form my local Motion industries supplier.
