Boost trouble, post MAF install.
I've also seen two different guys mix up the air/oil separator and IAC valve lines when swapping pipes and adding a MAF at the same time.
The Impaler
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Im getting around 15 vac at idle... im about to go for another run and see if ive fixed anything...
Small Business Partner
Originally Posted by Lorax
Its almost hitting a wall at 14 psi. Could it be that the BOV spring is too weak for the amount of pressure im trying to run?
Rogue
The Impaler
Originally Posted by ilikemy944
You work saturday?
Yeah... Im getting a new schedual very soon that will free up saturdays.... Maybe as soon as next week.
