Why am I getting too much boost?
After assembling my clutch again, I show 21 PSI on the boost gauge when turned all the way down. This is not good....... What do you think it could be? A leak in the line to the top port of the Tial?..........
Originally Posted by The DareDevil
Just run it at 21psi ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
And I can turn it up more.... so its hooked up correctlly......
Hmm I'd be careful here. This sounds a bit like when my Tial jammed shut on the track and even with no boost dialled in it was getting very high psi. It hit 2.1 bar which is over 30 psi. With the helmet on I couldn't hear the engine pinging it's head off so lucky the whole thing didn't explode. Testament to the stock engine components though. We tried turning the ebc right down but it wouldn't respond much so I'd check out the 'gate.
Rocket Scientist
Possible, but unlikely it's the Tial. Check your lines again. Disconnect it from the charge pipe and blow in it. If you can blow in it, and it leaks, there's your problem. If not, check your controller and WG. That's it. Only so many things it can be.
Have you had good results blowing on the pipe all the time?
Rocket Scientist
Originally Posted by special tool
Wow - this is a good idea, Derrick.
I blow the pipe daily, Thanks. Works wonders. You should try it sometime, Tool.
Originally Posted by Geneqco
I've heard of a few incidents with the Tial. Any idea what makes them jam shut?
