intercooler
Originally Posted by AlexE
You know I used to think that the stock intercooler was king................but having recently replaced my intercooler with a custom setup. I can't imagine trying to run those kind of numbers (600hp) for any extended time ...... That thing gets heat soaked incredibly fast, it is highly restrictive and frankly does a ****ty job of dropping the IAT temps...
I have kept logs of my car for the last couple of years and this last month has made me a believer that if you go over 300rwhp the stock intercooler must go.
THe first thing I noticed were much cooler IAT temps , less pressure drop and the biggest surprise was the ability to develop boost at idle? Now I blip the throttle 2-3 times and I can build 7 psi of boost..........
I have been amazed by my findings so far.
But then again those are just my humble opinions.....
That one is a 3.5 x 12 x 18.
I was thinking of going 5x12x18 or a 5x18x18............. chickened out. I was too worried about the lag factor.......... I went to do some logging tonight at had full boost at 3083 rpm. So no issues with lag. (Running Vitesse stage 2)
You have to cut........ not for the faint at heart. We braced up the front rails and all is well.
If you are afraid of cutting.......I would pipe it under the support like TIM does on the SFR unit. Frankly any intercooler should fair better than the stock one. I have yet to see an aftermarket intercooler perform worse.
While on the intercooler topic, does anybody have any experience with the lindsey upgrades to the stock intercooler?
That may be a possibility for your 928 Kevin, if you don't want to go custom.
http://www.lindseyracing.com/Merchan...1INTERCOOLER12
Originally Posted by TRP951
does that fit without cutting the body?
Originally Posted by Soloracer
Alex: That thing is huge. Any concerns with engine temps due to restricted airflow through the radiator with that set up?
Here is a picture of my latest ic.
This core is the same as Alex's, except it's 1/2 inch thicker.
In this picture, the mounting is finished.
All the bodywork fits perfectly on top.
Rocket Scientist
Here a picture of my intercooler WIP. This is about the largest one that could be fitted in. It is based on a Bell core, 18x18x3,5. Tanks will be custom fabricated
![](http://951r.951net.nl/images/P1020165_Intercoooler.jpg)
On a hot day the OEM intercooler heat soaks with my current 300+ HP track car, we have seen temperatures of 170+. Hope it is not going to happen with this monster.
As to blocking the radiator, out local specialist claims the temps will not increase with more then 5 C. We will compensate that with completely ducting the airflow through the hood.
As to blocking the radiator, out lokal specialist claim the temps will not increase with more then 5 C. We will compensate that with completely ducting the airflow through the hood.
I agree - this is what I have done also.
wow, looks good hans, what kind of tank-design has he decided on?
tubes and such is always cool, but I need the liscense plates and the DMV doesn't like stuff like that![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
also, got any progress blog/thread? or should I just check your page every now and then?
Hehe, it's a good thing you didn't go that large!
ST, thanks for responding to my PM.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
