Apexi AVC-R ebc wiring
I just wanted some assistance please with wiring up the Apexi AVC-R electronic boost controller – the Porsche wiring diagrams are a little hard to follow.
I need to know what DME plug # and colour is best for the following two ebc signal wires as described in the Apexi manual:
1. Purple wire (RPM signal or Injector signal) - which plug and colour should I use in the DME?
2. White wire (Speed signal) – I assume this is a road speed input, but where do I find it?
Thanks in advance for your help.
Scott, you can go down to the shop where mine is beached and check it out or ask Sean. I have the same ebc.
Patrick
Patrick
Yes Wayne has a great site and is very accomplished in much of the work himself.
Yes thanks Sean... Marked with a big "B".
You wouldn't by any chance know which is the signal wire for the Tacho would you? I installed a UEGO 2000 last night. It has a nice replay feature that requires you to tee into the Tacho, but it's difficult for me to work out which terminal to use.
Thanks again... good to see your progress with 'Project 2.7'!
